I purchase above pen drive two months ago. I want to format this pen drive but there is an error “The disk is write protected”
so plz solve this problem.
thanks!
if the drive is write protected then you cannot format it. the only thing you can do is to try with another pc to see if you can format it there. if that also does not work then it seems that the drive is defective and needs to be replaced.
Most probably, this might already be bricked. If it’s still the same behavior on other PCs, I’d check if this is still under warranty. ![]()
If it was purchased “two months ago” it is.
“I purchase above pen drive two months ago.”
