The range of FM stations only goes from 75 - 90. Can I change this? There’s only one station in that range.
In options there is something like FM format…you have to change it from USA format to WORLD format
Go into your Settings menu, scroll to FM settings. Are you in the USA? If you are, it would be odd that your range would be that small. USA settings should be from 87.5 to 108.0 MHz. If they’re not, something is wrong with your region setting. Could be you have the incorrect regional firmware.
