Right click add to player/folder in Windows
I want a option in the right click menu of windows to make it easy to add files of my sansa clip plus.  I can do this with under “send to”, but not specify what folder in the player I want it in.
Im sure the solution is real simple.  Will give thanks later
http://lifehacker.com/248320/download-of-the-day-send-to-toys-windows
(Has links for Send To Powertoys and, further down, versions for Vista and Win7.)
http://lifehacker.com/5640841/edit-the-windows-7-send-to-menu-without-third-party-tools
Perfect! Dank you
