I did a file backup on my WD Passport 1600 prior to doing a system recover on my e-machine T5224 Windows Vista Home Premium. My question is how do I restore those files?? I cannot seem to figure it out, I think I am missing a program or something the files are there but when I go to windows system restore it does not list that restore point? Does anyone have any idea’s I sure would appreciate it. Now they show up as backup zip files on the WD Drive if that helps. I seem to remember there being a installed application of the Passport that sort of walked you through it, was that WDSYNC?
Well WD Sync is not a backup software
this is a sync software and you’ll need the same app to restore the files
the sad part is that is not compatible with Win 7
you can connect to a computer with XP or Vista and then migrate the files once they have been "decompressed "
