Retrieval af formatted Data
Due to problems with connection on different windows systems my HD crached and where not accesable so I had til format it. Is there chance are redoing this? What program do I need etc?
It is depend on the way you formatted the drive.
Ive used windows formatting?
Please help its all my data thats lost if i dont find a solution
Hi lindegaard, if you formatted your hard drive don’t copy any new files since this might permanently delete some of them. There are several data recovery programs you can use to scan your hard drive and recover files, do a Google search and some options should appear.
winXP, win7, win8 ? full format or short one?
