Reset to factory settings 1 tb passport
i accidently formated my harddrive with my xbox 360, erased everything i didnt back up anything.
it was fat 32 so i formatted it with my laptop to ntfs, but i want it back to factory settings, btw i juts got this two days ago.
Look for a formatting utility that allows you to format the drive on FAT32.
You can also format the drive on a Mac as a FAT32 partition.
For more information:
How to format a WD external hard drive in FAT32 (to use in Windows or Mac OSX)
http://wdc.custhelp.com/app/answers/detail/a_id/291
i just want it back to the way i bought it. anyway to do this?
You will only need the applications that come on the drive to accomplish that.
You can download the applications on the link bellow:
http://support.wdc.com/product/download.asp?level1=2&lang=en
