First off I would like to say thank you for creating this product. I’ve been looking for something similar to this for a long time to use in my families’ long travels during vacations.
Even though the primary functionality is there, I wish it had a feature that would make most of the issues I have with the product disappear.
Is there any way possible to have the option to setup the wireless media drive as a UPnP/DLNA device?
This would allow me to use the third party apps I have purchased that support media streaming through UPnP with the video and audio formats I need supported. As of now, all of my videos would need to be converted in order to view them on the Sandisk app. I’ve seen the suggestion to use real player cloud, but that is not a convenient solution as I have to be connected to the internet and upload the file before steaming it. Most of my movies are larger than half a GB.
Also, what are you using as the connection and streaming protocol? Is this an open standard where I could possible develop or find an app that could access the Sandisk WMD?
Thanks for any help or suggestions you can provide.
Patrick
