My humblest apologies! I’ve discovered that if I try to clean up the first post in a thread, the board drops the thread. Here’s mommysantiago’s original question: -µsansa
I washed my son’s Fuze in the washer now it’s not working. It does turn on but it doesn’t play and the screen is blank. Any suggestions?
As you see, I did a little washing myself! Leave the Fuze turned off , and allow it to dry after shaking as much water from the Fuze as possible. This process can be greatly improved by placing the Fuze in a small bag filled with rice, believe it or not.
The rice is a wonderful dessicant, absorbing the moisture from the drying Sansa. Place the combination in a warm, (not hot!) and dry place for a few days. Patience is key.
If you search the boards here, you will find many success stories after this unfortunate accident.
µsansa
