I read the How To Informational on Replay Gain. Downloaded Media Monkey and applied Analyze Volume Level to my mp3 library both album and track. For 90% of the tracks when I transfer them to Clip+ the Replay Gain info is there as listed at the bottom of Track Info and it seems to work. However, I have some tracks that show the replay gain information in Media Monkey but it is not transferring to Clip+. If I delete the songs from the Clip+ and then add them again the information still isn’t there. Therefore I have deduced this is not some random file transfer error. Has anyone else experienced this problem and more importantly can you tell me how to fix this. Could this be a Media Monkey problem and not a Clip+ problem? I don’t have any other players that use Replay Gain to test this on.
Thanks
3-11-10 11:30 a.m. (CST)
Ok, it appears that the problem lies maybe with MM not Clip+. It appears that maybe the info didn’t get to the tag or that it requires Album levels. A couple of the songs I was having the problem on only had Track level information. When I added Album level info the infromation was there after I sent to Clip+. I would still appreciate any comments or insight into Replay Gain as it is a new feature for me.
Thanks
Message Edited by Orion3 on 03-11-2010 11:32 AM
