Weeeell as far as im concerned i got replay gain working on the Clip+ with MP3, FLAC and OGG files.
Heres how i did it:
1.: you would want to update the Clip+ Firmware to the newest 1.02.15
2.: get foobar 2000
3.: copy the stuff you want to work on to your harddisk, or youll grow a beard and get children while tagging
4.: point foobars media library to the folder with the files on your HD
5.: select all the files, right click => properties => tools => remove tags
6.: retag the stuff using freedb
7.: select desired files and do your prefered replay gain scan (per file, album, blabla)
i recommend "Scan Selection as Albums (by tags)
8.: apply replay gain info, copy the files back to your Clip
9.: unplug and grow a beard while it’s “refreshing your media” (screw you little mean player thingy)
10.: enable replay gain, play a song and see the info for yourself under “track information”, you can fiddle around with the pre gain value to actually hear the effect.
PS:
Aww ■■■■. If you may have hoped to get the **bleep** Clip louder with applying replay gain, you thought wrong.
Guess ill have to buy a portable amp after all. Poor wallet.
PPS:
This is a bugmenot account. Dont bother PM’ing it.
