Our My Book Live has given 10 years of Sterling service but now seems to have failed, despite the software reporting all is well with the backup which is not the case. Looking for a similar solution. Recommendations please
You should try contacting WD’s Technical Support for drive replacement
No longer supported I’m afraid
