Replacement enclosure for Damaged 2.0 Connector
I have a 2010 purchased WD Passport Model: WD3200ME-01, S/N: WXA0A8900991. MOst of the time drive is working perfectly fine. Sometimes the drive does not get detected and I have to keep plugging cables and remove it before laptop detects the drive and then it works fine. The cable works fine with my other WD drive so it is not a cable fault. I think it is an issue with connector. Can I buy a enclosure with connector from WD India?
