Recently had firmware update fry bios. Dell replaced mobo with same spec mobo (of course the board ID# changed) . I believe data was saved as Raid 0 (continuous 2 drives). There was apprx.400mb backed up.
I would think data is saved only on drive 1. I haven’t reconnected/started My Book Duo. Can I access the My Book Duo without issues and retrieve data? If not, can I use a 3.0 USB-SATA conversion cable to access the drives (if so will the data be readable)?
Dell 5040
Intel i5-6600 CPU @ 3.30GHz, 3312 Mhz, 4 Core
Prior Sys ID Name: A36ECQB
New Sys ID Name: U0L5HNN
My Book Duo 2-2Tb drives
Thank you for assistance,
Scott
