I have been very satisfied with my first three WD Passport drives - 60, 250 & 320GB. So when I saw the 1TG version, I bought three more.
After a short while, I discovered how WD have destroyed a superb product with this ‘SmartWare’. With other drive products that come with backup software, it’s been easy to simply delete the unwanted files and recover the wasted disk space. I use ViceVersa PRO for all my backing-up, which is a very flexible and easy to use product. Not free, but worth every penny.
With these three new WD Passport drives, I discovered that to use them, I needed to upgrade the firmware. I’ve never had to do this with any other drive product. Then I needed to hide the virtual CD. This required downloading both utility programs.
I was able to do this on my desktop (that is connected to the internet), but was unable to do this on my two laptops. Incidentally, all are running different versions of XP Pro, SP3.
Every time I connected a drive, I saw the driver wizard appear and end in an error. In the XP ‘Drive Manager’, the main disk appeared correctly, but there was always a couple of yellow blobs, hi-lighting the failed driver for the virtual CD.
So I copied the .sys drivers from the desktop to the laptops, but they would not install, whatever I tried to do.
After many hours of tests, I discovered by using my third new WD Passport on a second desktop, that before running any of the update or CD hiding utilities, I could read the virtual CD and copy the driver and it’s .inf file to a USB memory stick. (wdcsam.sys & wdcsam.inf)
Then using these files, I could install the drivers onto the laptops. Incidentally the driver wizard has to be run many times for every computer. This gave me a working driver for both drives (HD & virtual CD) without any yellow blobs!
The HD works correctly and the virtual CD is completely hidden, so does not use up a drive letter.
Unfortunately the half gig lost can’t be recovered, but in 1000 gig that’s not a problem.
One advantage of these new non-standard cables is that the volt drop problem experienced with my previous larger drive on a battery powered laptop does not occur. So that’s a plus point !
Reg
