How can I reinstall Smartware that was uninstalled accidently (don’t ask). If I do a factory settings restore of My Cloud will it reinstall Smartware?
You just need to download the software from our site and you will be able to install the application.
See if the following link helps.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705057.pdf
to download the application see the following link.
