I have been reading forum about the refresh data frozen screen when you download music and disconnect from the PC, I have the same problem I have updated the firmware and everything else works fine.I have been reading about forcing the clip into format to FAT16 can someone explain in easy terms how to do this
do that from pc while connected… it will give options… this probly isnt the prob… you probly have a bad tag on a song.
delete all songs, see what happens… if it boots, you know the prob, reload few at a time unplugging in between… redo tag when you find the bad tag. use “mp3tag” (free) or umpteen other apps
