Hi, can anyone assist with commands to reformat my passport so I can use it with WD mini media player?
I have deleted the commands that came on the passport, any ideas??
Try posting in the TV section you’ll probably get more notice
Joe
Make sure its not journaled here are the instructions
the link you posted will show how to format as journaled emgee does not want it journaled but thanks anyways for trying
Yes but if you already formated the drive you dont have to re-format the again, You can also disable the Journaling
here’s the link
