reformatting the clip?
    i recently purchased a macbook and plugged my clip into the usb port for the night…the next morning it was blank and did not respond to anything.
can i reformat this?  how?
thanks for your help,
careyonon
hi, as far as i know only windows xp or vista is supported by the clip and it might work in a mac as an msc device but might cause issues. try to soft reset the player by sliding the power switch to the up position and holding it for about 20 to 30 secs. then move the switch back to the middle and leave it for about 5 secs then turn it on and see what happens. if that won’t fix it, you need to use an xp computer to format the clip.
Message Edited by CliPm0j0 on 03-01-2008 06:20 PM
