What format does the voice recorder record to? Also, will it record off of FM?
Records in WAV format. Also records FM, though strangely enough, this isn’t mentioned in the Quick Start guide included with the player.
Just incase you were looking for a bit more detail codec is pcm at 24,000 Hz for both voice and fm recording.
However voice bitrate is at 768 Kbps while FM is 384 Kbps.
Also Voice is recorded in Mono while FM in Stereo.
Message Edited by thoma on 04-02-2008 03:40 PM
Anyone know how long I can record off FM? I’m hoping to get about 6 hours.
Thanks.
there is no limit unless you set one. it should keep recording until memory is full, or you run out of batteries.
What if the builtin memory is full, will recording continue on the card?
