I have a Sansa fuze ,I took the cover of to repair the audio is there anyone who can tell me where the strip at the bottom fits into as it came away but is still attatched to the face plate
This might help:
http://anythingbutipod.com/2008/03/sandisk-sansa-fuze-disassembly/
Good luck making the strip connect. It’s sucha short cord, and hard to reach. I ruined my first Fuze trying to dissassemble/reassemble it.
There is a small black lever on the opossing end of the white connector (not the side where the data strip came out from). you lift it gently, and then you can insert the strip carefully, and lock it back down. I hope it helps.
