Recharging questions
I’ve been reading about recharging in the manual and on the board and looked at videos on YouTube , but I’m still not sure about recharging my clip+
Should the clip+ be turned on while recharging attached to my computer? While attached to my usb wall adapter?
If it is turned on while recharging what screen should I be seeing?
Thanks!
It will turn on automatically when you plug it into your computer and start charging. You’ll see the Connected Screen with animated battery icon alternating with the SanDisk logo screen.
You can’t turn it off.
Thanks, Tapeworm - I am seeing that screen – and the battery icon up in the corner is now showing solid. (And I’m enjoying this little clip+!)
Then take the fork out . . . it’s done! :stuck_out_tongue:
