Hi.
My WD Book Studio 6TB have failed. However, the drive’s SMART status is good when checked in another My Book…
So, does anyone have a tip on how to remount the RAID 0-set ? When I tried the drives in my other WD box, the Raid set was not recognized.
PC/Mac/Linux, whatever it takes.
Unfortunately, RAID 0 does not provide fault tolerance against controller or disk failures. The entire volume is compromised.
Thanks for your advice, but you see, it seems just the controller is gone, and the disks are still usable.
I had a faint hope someone may know if the WD controller f.ex. used a standard linux file system as some other raid-enclosures do. In that case I may have a chance rebuilding on a linux-box…
