I have a WD Blue 250 GB SSD with a damaged GPT Table I have a backup of all the data. Everything I try using Active@BootDisk throws up an error message stating that the GPT table is severely damaged and the action could not be completed.
As mentioned, I do not care about the data, I would just like to re-initialize the disk.
Any suggestions?
Thanks
Graham
[SOLVED]
I converted the GPT to MBR, Deleted the old partitions and re-converted back to GPT
Graham.
