Here is a quick way to access Device Manager and Disk Drive Manager.
Copy and paste to Windows address bar or to Internet Explorer Address bar and hit enter.
Or you could create new shortcuts using these codes!! :smiley:
Device Manager:
C:\Windows\System32\devmgmt.msc
Disk Drive Manager:
C:\Windows\System32\diskmgmt.msc
Mabikay – SLK
Note: Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the ‘Accept as Solution’ button for the post that solved your issue. …
It’s funny that WD support site or anyone else in here had not thought of that until now. All were pointing here and there, how to navigate to disk manager or device manager using conventional paths.
Maybe they had it, ´´Im positive´´, but did not want to share it with someone else…Or maybe was not the time to, I guess hahahaah, as someone said knowledge is power isn´t it? hahahaa …
