My new Fuze came with some pre-loaded .bmp files in the Photo folder and some pre-loaded .jpg files in the Pictures folder. What are these files for? If I delete them, will I screw anything up? Will I save memory that could otherwise be used for music?
Thanks.
JEP
Yes, you can safely delete them.
Yes, you can use the space for music instead (but the total space used by the pics probably only equals 1 or 2 average songs. 3 at most.)
Thye’re just samples, same as the songs that are pre-loaded on there. If you want to clear them out all at once, just use the Format function in the Settings > System Settings menu.
Thanks. I’ll delete them.
JEP
