I have an elements 1 TB desktop external drive that I obtained in 2009, and I have a couple of questions.
First, I see that there’s a knoledge base article about power adapters for WD products. However, the links that are supposed to point to the product pages look a bit out of date. So my question is this: Are the current 18 volt power supplies currently available compatible with older elements desktop drives like mine?
Second, will my older drive work with Windows 10, or will I need to get a new drive and transfer files?
These drives are no longer being manufactured, however, I suggest you contact WD Support to check if they still have some in inventory.
Also, your drive should work with Windows 10, but I do suggest you keep a backup of your data just in case.
Ah okay, will try support. I just really needed to know if the current 18 volt adapters were compatible with older drives since the links to the product pages in the knowledge base article aren’t even the right format. They end up redirecting you to the main WDC page. The plastic on my adaptor’s cord is starting to crack, and even though that’s just a 18 volt adapter, that sounds a bit dangerous.
