Hi, have not got the Express yet just goin to ask before i do can u put data files and other things like that on it?? Thanks for the help!!!
yes you can… even on MTP!
if you see a Data Folder inside ‘sansa express - internal memory’ drop your files there. if not, just create one.
Hey thanks alot helps in the decision!!! Pictures too? Had to ask.
No picture support for the Express.
The device will accept pictures and other documents stored as data (like a flashdrive), but it will not display pictures on the OLED screen.
Sorry did not read all the previous posts…yes you can store any type of data on the Express including picture files.
