if you want Split Large PST files without corrupting it, then I will recommend you to for some automatic tool.
KDETools pst splitter full version software quickly Split Number of PST files in similar files formats. This pst splitter tool is the best advanced software, that allows the user to reduce oversized and large PST files into small parts depending on your need.
