I just bought a Sansa Shaker and loaded it with music for my daughter. I’m having problems with the Shaker Cap. It’s so loose that when I use the Bottom Twist feature, the cap falls right off. Is there a way to “lock” the cap in place?
it should kinda “Click” into place… at least thats the way it appears from the store i tried it in
Same thing was happening to me. Really push down on it as you turn & click it into place. That worked for me. Good Luck!
Thanks for tips. I was having the same problem with the cap. I pushed and turned harder and heard the click.
Also thanks for this tip - I’d thought both of ours were broken already, but pushing a little harder does result in a “click” and it locks back into place.
I was having problems with the cap falling off also. So I pushed down on it as suggested and now it stays on but I have a hard time gettting it off. Is there a trick to that also?
