I had no problem downloading the songs but when I shake or turn more than 3 times the player shuts off automatically and when I turn it back on it starts at the beginning. The same goes for reverse turning. Anyone else with similar problems? If I just let it play on its own it will go farther but then it takes forever to get to you 200th song!!!
HHmmm… It’s def a problem with the device. You may need to contact tech support. There isnt’ much u can do with the device it’s self to fix it.
