I’m having a problem charging my Fuze. I plug it in it charges for maybe 30 seconds and then just stops. I’ve tried multiple USB ports on my computer (front&back) but nothing seems to work. Please help.
Thanks.
Thanks.
How do you know it stops. Are your Fuze already fully charged?
Sounds strange to me, you can try to reboot your machine then do it again.
Thanks.
Message Edited by kevin02454 on 12-25-2008 06:01 PM
It flashes with the bolt next to it and then after a short while stops and the battery bar is completely white. It’s not fully charged because when I take out the USB cord it turns off.
Does the pc recognize that the Fuze is connected? I guess not? If not, then try this.
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&thread.id=2623
What machine do you use? A pretty old machine?
