problem with radio
Hi I am from Poland and have problem with radio in sansa clip 2 gb with fm. I have sennheiser headphones model hd 202. And when move my headphone cable or roll it I have  interference. This is very frustrating when I am in bus etc. What should i do ? Mp3 plays correctly. I have try world and USA radio region with no effect. I have noticed that when i little shake player something is moving in it :). Maybe this is the reason of my radio problem ? Should I  complain it in shop ? Thanks for answering.
Your earphones function as the antenna for your player, so the problem may be in your headset.
To tell if it is the player or headset, try another pair of head sets. If they work, the player is good and the original headset has a problem.
If that does not fix your issue, try the headsets in another device. If they work in the other device the player is the problem. Headset jacks cannot be repaired, so return the player to where you bought it or contact SanDisk Technical Support for  return and replacement, assuming the unit is still in warranty.
Hi i have tried with headset included with player and when move cable in some position there is an interference :confused:
 It seems the problem is in the player’s headphone jack.
So properly there should be no interferences when moving headphones and should get all the radio station wchich are in the place ? I need to know when will talk with guy where i bought my clip.
I have noticed that when i little shake player something is moving in it :smiley: This is normal ? When i want roll my long headphone cable i have interferences what should i do ?
The loose item you hear is the Power switch slider.  Hold a finger over that wee beastie and your Clip should be silent.
Bob  :smileyvery-happy:
Hi, I have problem with interferences in my clip’s radio with any headphones. With long and short cable it doesn’t matter. I am dissapointed because i bought clip with radio to play it in the bus, train etc. I often have interferences when i am not in move. What should I do to have correct radio ? Please answer :slight_smile:
The headphone plug is firmly seated. And the interference is still. Are some signal amplifier or mobile antennas ? What should I do to have no interferences, but please don’t write about giving headphone cable to another position. :slight_smile: Do you have the same problem ? I have updated firmware with sansa updater.
I have this headphones:
http://www.sennheiser.com/sennheiser/icm\_eng.nsf/root/05176
The problem is with it’s cable ?
