Hello guys
i have this drive for one year now it was working fine till yesterday i was trying to play a movie from it and i found that it stopping randmoly … i tried to copy the movie but it stay forever and no prgress then i tried with some other files some of them i was able to copy just fine and the other was the same stay forever then i have to cancel the copy
i was aware that it might be a bad sector so i ran chkdsk drive letter: /f command and it stopped responding at the some point so i had to stop it by ending task for the cmd window and now my drive is almost dead
when i plug to the pc i get just local disk label no space nothing and i can’t even and it take forrver for proprties to appear and when i try to do check i got that windows can’t access the drive
tried with partition magic , acronis , wd lifeguard and they can’t see the drive
disk regenrator can see it but it stops after while when i try to scen the disk for bad sector
the problem is it got 800gb from my valuable data and when i open the housing of the drive i found that usb to that stupid port so i can’t use SATA even
anyone know anyway i can restore my data or save anything ?
