I updated my e280 using the Sansa Updater, then I restarted it. As it boots up the message says “Refresh Database” with a progress bar. The bar gets to a little over half way and then the screen goes blank. Eventually I press and hold the power button to reset the unit and the same message comes back. It locks up each time. Has anyone had this problem? Any ideas? Thanks.
