Problem re-partitioning Mybook 3TB
Bought a 3TB Mybook last week and tried re-partitioning when I came across the same problem as:
http://community.wdc.com/t5/My-Book-for-PC/Problem-re-partitioning-3TB-My-Book-Essential/m-p/116402
However, I deleted all partitions so I still have 2 non- allocated parts on the drive. One of 2048 GB, one of 746GB.
How can I put them together so I can follow the rest of the steps described in above mentioned post?
I searched this site, the WD site and the net, but nowhere can I find how to put those 2 together.
Thanks in advance for the help!
You need to use GPT for 3 T not MRB check post 4 http://community.wdc.com/t5/My-Book-for-PC/3TB-Essential-Win-7-32-bit-System-Backup-Failing/m-p/126100/highlight/false#M4597  see if that helps
Joe
