# Problem acceding WD MyPasport 4TB
**URL:** <https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646>\
**Category:** Portable SSD\
**Created:** [January 21, 2020, 11:26am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646 "2020-01-21T11:26:06Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![xusmen69](https://avatars.discourse-cdn.com/v4/letter/x/41988e/32.png) [@xusmen69](https://forums.sandisk.com/u/xusmen69)\
**Post date:** [January 21, 2020, 11:26am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/1 "2020-01-21T11:26:06Z")
</div>
Few months ago I bought a WD MyPasport 4TB disk, and recently, when I tried to access in Windows 10 SO, I saw the disk in the disk list, but it doesn’t specified disk usage, and when I tried to open the disk the windows freezed and never stop freezig, and when unplugged the disk the freezing state dissapear.
The disk ran properly before this situation, I tried to mount in linux system and appeared the next errors on logs:
blk\_update\_request: critical medium error
Buffer I/O error on xxx, logical block xxx, async page read
I tried to execute analysys of the surface and the app returns that is ok, and I tried chfdsk /f in windows but runs very slowly and never finished, for the slow speed.
I didn’t setted any password for the device.
¿Can I format he partition and recover the files with testDisk, for example? ¿or is not possible with default encryption?
**Author:** ![flash67](https://sea2.discourse-cdn.com/sandisk/user_avatar/forums.sandisk.com/flash67/32/42562_2.png) [@flash67](https://forums.sandisk.com/u/flash67)\
**Post date:** [January 22, 2020, 9:50am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/2 "2020-01-22T09:50:16Z")
</div>
I am having the same problem since a few days ago, windows 10, my passport 4TB, windows grinds to a halt, unusable very slow when my passport 4TB plugged in, as soon as I unplug it, windows works perfectly again. I only bought it a few months ago. Cannot access files on drive.
**Post date:** [January 24, 2020, 7:57am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/3 "2020-01-24T07:57:19Z")
</div>
Another topic with similar case:
> [@WD external harddisk cannot be read or accessed](https://community.wd.com/t/wd-external-harddisk-cannot-be-read-or-accessed/246409):
> My WD passport external hard disk is of 2 TB. I can see the HDD shown as some local disk(not with the HDD given name) but it cannot be accessed. And windows explorer stops responding if i try to access it. So let me summarise the points i have on my problem: problem points: after connecting it to the device, it continuously blinks and i can hear sound that it is running inside. But in file manager, it just shows the disk name (like Local Disk H) not my harddisk name. And I cannot acces…
**Author:** ![nzsuzsan](https://avatars.discourse-cdn.com/v4/letter/n/a4c791/32.png) [@nzsuzsan](https://forums.sandisk.com/u/nzsuzsan)\
**Post date:** [January 24, 2020, 8:05am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/4 "2020-01-24T08:05:21Z")
</div>
Hello, I am having issues very much alike to what is described above. I have precious files on the harddrive (WD 1913B 1TB, bought a few years ago, little used, never had any issues). Tried on 3 computers, same result. I would like to fix it, hope I get help from this community. Thank you.
**Post date:** [January 24, 2020, 8:26am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/5 "2020-01-24T08:26:44Z")
</div>
I’m at the same situation, and it seems that more people have been having the same problem recently, we have waiting for a response from WD.
**Author:** ![Pradeep.sagili](https://avatars.discourse-cdn.com/v4/letter/p/ecc23a/32.png) [@Pradeep.sagili](https://forums.sandisk.com/u/Pradeep.sagili)\
**Post date:** [February 1, 2020, 6:34am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/6 "2020-02-01T06:34:40Z")
</div>
i am facing the same problem, i have warranty but what happen to the data.
**Author:** ![robert11410](https://avatars.discourse-cdn.com/v4/letter/r/ba8739/32.png) [@robert11410](https://forums.sandisk.com/u/robert11410)\
**Post date:** [February 1, 2020, 11:31am UTC](https://forums.sandisk.com/t/problem-acceding-wd-mypasport-4tb/408646/7 "2020-02-01T11:31:05Z")
</div>
im having identical problems with my unit
