I recently bought a refurbished SanDisk Sansa c100 mp3 player and lost the USB cable and I need a new one… I was just wondering if the SanDisk USB 30-pin Connector Cable is compatible with the c100? The c100 wasn’t listed under the compatible devices, probably because it’s old… so if anybody knows please let me know …thanks.
yes the 30 pin cable will work with the c100
thanks
A wise man once said, “The only dumb question is the one that isn’t asked.”
