PrivateAccess backup stuck at 99%
When I try to load in a backup in the Private Access Vault it all goes well until it reaches 99% at which point it gets stuck and stops doing anything. It shows no data is being transferred when I check the Task Manager. Is there any way to fix it?
Hi @Blocksygustav1
