Hi to all… I had an iPod, and now I got a Fuze… When I had the iPod, I changed the Equalizer for each song on iTunes, and setting the iPod EQ as “normal”, it took the EQ settes on the PC… Did it work also on the Fuze with the “custom” EQ? And, if yes, can I set it without iTunes? Thank you
When you set the Fuze’s Custom EQ to your preferences, it will apply those settings to all your music. There’s no way to program a different custom EQ setting for different songs.
