@tasar731 wrote:
Pre-amp is a Densen B200, power-amp B310, speakers Dynaudio Audience 82
Connection is a DIY mini jack to L/R phonos
Volume on Fuze set to a whisker off maximum yet pre-amp volume needs to be at about the quarter past position still not quite enough volume and I’m not particularly comfortable with the pre-amp volume sitting so high.
I can hear it, I suppose by some standards it could be considered loud but it can’t compare in this respect with my CD player (also Densen) which must have a higher output than the Fuze. It could be that the impedence of the pre-amplifiers input is too high for the Fuze preventing it from generating enough power.
The docking station suggestion could be the answer, I especially like the remote control aspect of it, but does it provide a higher output than the Fuze itself or is it merely a “conduit” for the Fuze’s signal.
Regards
Interesting. I don’t find any reference to the input impedance of your pre- on the Densen website. I downloaded a PDF manual, in German, unfortunately, but even so, I could find no reference to input impedance in the tech specs near the end of the document. My integrated amp’s pre- section has an input impedance of 22kOhms, which, while not terribly high, is approximately an order of magnitude larger than headphones. The Fuze will drive it ‘fully’ when running through the pre-amp section. Running straight to the amp section, it drives it to an acceptable listening level, but not loud. I normally have my volume control set at quarter-til, or a bit lower. I’m running Klipsch KG-2’s at the moment, 4Ohm. Other sources are approximately the same level, tuner, PC out, etc.
I believe the docking station will simply enable the line-out of the Fuze, not add anything to it. You can do a Google for ‘Fuze DIY line-out’ to find some information. As I understand it, basically the signal level from the line out is approximately the same as max headphone out, but is a marginally cleaner signal as it is taken from a point earlier in the chain to the headphone out.
Do you have another rig you can try the Fuze out with? Maybe a friend or neighbor? I’m curious as to what’s going on.
