Has anyone else found that to power it off you have to make it light up first?? I have been noticing that for the past few weeks.
That was an issue that was discovered in the last firmware version. The player would even occasionally freeze up, necessitating a reset. It’s listed under the ‘Bugs fixed’ in the most recent update released last week. What version of firmware are you running? If you didn’t update last week, you may want to and then check it again.
That was an issue that was discovered in the last firmware version. The player would even occasionally freeze up, necessitating a reset. It’s listed under the ‘Bugs fixed’ in the most recent update released 12/12/08. What version of firmware are you running? If you didn’t update last week, you may want to and then check it again.
the fix that problem like year’s ago
J.K on the year’s ago
