Power Cord Failed
Ok, bought this less then 1 year ago and it looks like the power cord failed. No light is coming on. Go to your website and it says not in stock but give email to notify when it is. I have to make some back ups weekly , can;t wait 2 months for this to come in. Tried to search online for an alternative but have not found one that works with this model - My Book WDBFJK0040HBK-0A- can’t tell if the zero is actually an O instead?
Thanks
Update, looks like they are zeros as I entered this into Google and found an alternative- never mind
Hi there, you can look for a power adapter with the same specs:
12 Volts
1.5 Amps
18 Watts
Or you can always contact support, they can help you with that.
https://support.wdc.com/support/case.aspx?lang=en
