Possible firmware bug
Player: Blk 2GB w/4GB MicroSD card
Firmware: 01.02.26A
Glitch: Backlight timing
The possible bug I found deals with the backlight timing. Whenever you set the timing to anything below 15 seconds, the player freezes and requires resetting.
i do not have this issue with my fuze.
I don’t either…just tried it with a 5 second setting.
I also tested it and I found that if I reset the backlight timing while a song was playing, the backlight will go out at the time set and the fuze will freeze up.  But if I stop play and then reset it, it’s okay.  Looks like a bug.
None of these happen to me.
I tried it twice just to be sure, the first at 5 seconds, the next at 45 seconds.  It froze both times and had to reset the fuze.  Personally, it’s a minor bug since I don’t reset the backlight timer alot and when I do, I just stop play, reset the timer, and all is well.
I’ve seen the same issue and I tried it while playing two different songs (although from the same album), both MP3s.  I don’t know if it happens consistently, and I never like to freeze up my Fuze on purpose (just feels like it’s going to cause more problems down the line).
I have a v2 sansa Fuze.
