Poor battery life on mid 2010 13" Macbook Pro after installing SSD
I’ve installed a 480gb SSDA-480G-G25 on a mid 2010 unibody 13" Macbook Pro with 8GB of RAM running the latest version (10.11.6) of El Capitan
I cloned my previous hard-drive onto the SSD and then swapped them.  My system booted up without problems and is noticebly faster(thank you).  However my battery life has more than halved since then, I’ve gone from 4-5 hours to 90 minutes.
Activity monitor shows there are no processes taking up significant CPU time
I’ve reset the SMC without any change & checked my firmware is up to date
Spotlight is not indexing the new drive
My battery has 1056 cycles and system report states that it’s condition is normal
My fan seems to have been on more than normal and my system temperature is sitting about 71 degrees celcius with a hard drive temperature of 48 degrees
I’d welcome your advice
Hi jm1979,
Is it possible that you run a SMART report for us and send us the result ? We want to see if the drive is doing anything in background and causing more power usage.
Do you have/recommend any specific(free) tools for getting the SMART report?
Thanks
smartctl 6.5 2016-05-07 r4318 [Darwin 15.6.0 x86_64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     SandForce Driven SSDs
Device Model:     SanDisk SDSSDA480G
Serial Number:    161952443207
LU WWN Device Id: 5 001b44 4a4b39996
Firmware Version: Z32070RL
User Capacity:    480,103,981,056 bytes [480 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Aug 23 08:26:51 2016 BST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (  120) seconds.
capabilities:  (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time:  (   2) minutes.
Extended self-test routine
recommended polling time:  (  10) minutes.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Retired_Block_Count     0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours_and_Msec 0x0032   000   100   000    Old_age   Always       -       13h+00m+00.000s
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       15
165 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       30066933789
166 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
167 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
168 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1
169 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
170 Reserve_Block_Count     0x0032   100   100   000    Old_age   Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_SandForce_Attr  0x0032   100   100   000    Old_age   Always       -       0
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       15
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   065   044   000    Old_age   Always       -       35 (Min/Max 0/56)
199 SATA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
230 Life_Curve_Status       0x0032   100   100   000    Old_age   Always       -       38655295497
232 Available_Reservd_Space 0x0033   100   100   004    Pre-fail  Always       -       100
233 SandForce_Internal      0x0032   100   100   000    Old_age   Always       -       325
234 SandForce_Internal      0x0032   100   100   000    Old_age   Always       -       538
241 Lifetime_Writes_GiB     0x0030   253   253   000    Old_age   Offline      -       413
242 Lifetime_Reads_GiB      0x0030   253   253   000    Old_age   Offline      -       182
244 Unknown_Attribute       0x0032   000   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
