I am curious if anyone here would be interested in an application (Windows) that would copy podcasts (mp3 files) from a directory on the computer to the directory you specify on the device. I have a simple, not ready for comercial use, application that I use with iTunes.
I generated a file of what directories in iTunes to copy to which directories on the Fuze. (I’d update the application to browse for directories).
It automatically adds a number to the beginging 001, 002 to keep the files in order in.
I use the Folder option in the xx.xx.26 software.
I have been using this software for a few months now and it works quite well.
If there is any interest I can clean up the software and indicate where to get a release.
Donations would be accepted, but not required.
Brian
