I got a e250 and i searched for the latest firmwares…and in “anythingbutipod.com” i found this new beta version ie 1.03.01 and i hated it…and now i am not able to remove it…it wont even show the startup page rather it refers straight to the home page…it wont even show the rockbox …i was not able to downgrade it…plz cananyone help me with this problem or should i give it to the sellers and get it repaired…plz help me…
just follow the instructions for loading the latest firmware for youplayer, wether it be version one or version 2. they are in the e200 section of the forum
it is not workin yaar…it doesnt even show the upgrading…when we unplug the sansa after copying the .mI4 files the sansa just dont do anything…it will be inthe same position itself…it doestnt even restart…i think i crashed my sansa…
it was for v2.0 yaar…i didnt knew it…**bleep**…my sansa was v1
when you talk…like this…its kinda…idk…,annoying, unneccessary?
Did you end up fixing the proplem?
nop…i was not able to fix that problem…can any one plz help…
i suggest you just call the support line and ahve them walk you through it over the phone, it does not seem like you know what your doing.
I got it working fine… i was able to remove the beta firmware…
