Helloo SanDisk aficionados!
As a favour for a friend I am trying to revive a Sandisk Cruzer Slice 4GB stick that has been chewed by a dog(!)
The outer casing has been damaged and the USB connection to the PCB has broken off, but the actual PCB seems fine.
I am electrotechnical and hope to repair the stick by taking apart a San Disk Ultra USB 3.00 16GB and using the USB connection part (presently I am on a boat and only have access to the Ultra; another Cruzer Slice would have been ideal)
Can anyone advise if the PCB to USB connector ‘fittings/tracks’ will be fairly compatible in terms of layout/architecture (for me to solder the USB connection from the Ultra to the Slice PCB)? Before I destroy the casing on the Ultra? Or would we have to try and obtain another Cruzer Slice?
Many Thanks for any help!!
