Please help me format my USB.
I want to format my 16gb Cruzer USB into NTFS format. In XP, I select right click format. When I do that only 200mb of the usb is formatted into NTFS. How do I make all 16gb format into NTFS?
Message Edited by pleasehelpme00 on 12-06-2009 12:04 AM
This might work. Select drive,right click,properties,hardware,device properties,policies,select optimize for performance. With optimize for performance checked, try your NTFS format procedure. Note NTFS will write cache the drive, so make sure when you write to it that it completes before you disconnect.
If all else fails, head to Google.
