I was loading a podcast on a card i just got, insterted it i nmy player and now for some reason it keep saying boot error, shutting down now".I’m on windows 98 so i can’t use the updater is there a way to manual fix this problem?
Kingston Memory is problematic.
You should NOT use it for any Sansa Player.
Do a search on the forums here and you’ll find plenty of information about
the problems people have had with Kingston memory.
I search and found that i need the fireware updater but i’m on windows 98 so i can’t use it, is there a way to fix thsi problem manually?
