I am building some playlists to load onto my new Fuze, am wondering if I use the same song in multiple playlists will this load it into the pod multiple times? I don’t want to fill the memory up with several copies of the same song.
First things first… Its not a pod… that is the induration of the ipod world making its way into your every day language.
As for the duplicates. It should not put the song on more than 1 time. This however is the rub. If I put a song on my internal memory and then sync a playlist with that song to the internal memory its perfect WMP says already on device. However if I sync the same play list to the External card it syncs the song again. As long as you keep playlists on the internal Card you should be ok!
